- Jul 30, 2024
What would be the easiest grind to do? I like the look of a scandi grind but I don’t know if that’s a grind for more skillful craftsman.
Agree with this... Scandi's are actually pretty difficult due to how low the grind height isSimplest is an FFG (Full Flat Grind). You grind/file/sand from the spine to the edge. You can also add the distal taper while doing it. A small secondary bevel is added to strengthen the edge when sharpening.
Some info here:
A Guide to Knife Grinds and Edges
Written by Timothy Martinez Jr. To beginners, a knife consists of two parts: a blade and a handle. This simplistic view of the knife is fine for most people, but if you want to know your knife on an intimate level, you must understand how every part of the knife influences how you use it. One...knife-depot.com
Indeed, the toughest thing with scandi grinds is that if they aren't perfectly flat, it'll show the first time it's sharpened on a stone.Agree with this... Scandi's are actually pretty difficult due to how low the grind height is
