I've looked up and read about different grind types but don't quiet understand grind types relationship with sharpening. Do you need to sharpen each grind type differently? And if you sharpen at the wrong angle can you completely destroy or change the type of grind that was originally put on the blade? Any info will be helpful
Would you mind clarifying your question? By "grind types" do you mean
hollow (concave) vs
flat vs
convex? And are you referring to the primary bevel or the secondary/edge bevel?
Starting from a blank or billet, the primary grind/bevel can be "chisel" = only one face is ground down to an edge with the flat of the opposing side
- or it can be "symmetrical" = each side is ground in the same way / at the same angle to create a mid-line edge
- or it can be "asymmetrical' = each side is ground in a different way / angle to an edge.
As posted above, a bevel may be ground hollow (concave), flat, or convex at a given angle of incidence (i.e. the angle at which the hone and billet intersect). Once the primary bevel is set, usually < 5 degrees per side, a secondary edge-bevel is applied to retain strength at the apex. This secondary bevel is often < 1/16" wide depending on thickness at the edge - thinner knives may have secondary bevels only ~1/64", a "microbevel". The edge bevel
can be ground any way you want - hollow, flat, convex, any angle. Less metal needs to be removed so, depending on the steel and the thickness/width of the bevel, it can be applied and adjusted relatively rapidly. Indeed, a more obtuse bevel can always be added to the apex "on top of" the edge bevel - a "tertiary" bevel. Changing the edge-bevel does NOT change the primary grind of the blade, does nothing to "destroy" the primary grind. To "completely destroy" the edge via sharpening at the "wrong angle" implies either poor technique - i.e. uneven or non-linear edge, burr, apex-rounding - or implies too low of an angle - i.e. the resulting edge is too fragile for the task and chips/folds readily. In general, with good technique, no you cannot "destroy" an edge by sharpening at an angle other than what was applied at the factory. Knife edges are customizable!! Learn/practice technique and have at it! Enjoy
