- Jun 3, 2019
I was grinding a Santoku a couple days ago (CPM154, 62 rockwell, Wa style tang). got into the now-enjoyed "Zen" of grind, dip, look, grind, dip, look, correct/extend bevel, straighten Shinogi, thin edge, check edge thickness, grind more to thin, etc etc, etc, move up to finer belts, check coarser marks are removed, go finer, etc, etc (finish with scotch bright)..... go back and correct the grind marks that I did not see until now, then go back up the grits, etc, etc...
Two hours later I was done. definitely not perfect (I still can not get a dead straight shinogi, probably need to hand sand for that) ... and so am still "blending". Still .... like has occurred before, I was TIRED (and had d little headache). It is not like I was running laps around the track or something .... but the focus and concentration of identifying what needs to be corrected, and making those fine corrections just takes a lot of energy, and almost always leaves me pretty drained.
Is it just me getting old .... or does the process affect others the same way?
