- Jun 8, 2000
Before you get all excited, no this isn't my new KMG. However, because I DO have a new KMG, I no longer have space in my shoebox sized shop for my Craftsman grinder, so it's for sale.
Here's the deal; Up for sale is a Craftsman 2"x42" belt/ 8" disk combination grinder. It is the older, beefier 3 wheel design (orig. $200.00) , NOT the current cheesier 2 wheel 2/3hp model. This grinder has mostly cast iron parts and is powered by a 1hp motor and set up for 110V single phase operation (plug in anywhere). It has a flat platen, belt tracking adjustment and adjustable angle on the work rest for the belt side and also has an adjustable work rest angle on the 8" disk side.
The grinder served me well to get me started in blade grinding and some guys still make some real nice knives on a similar machine. It is used, but in overall good condition. There is only one modification that has been made to the grinder. The bolt that secures the belt side work rest eventually stripped out as it needs to be unbolted and the work rest removed every time you want to change the belt as configured from the factory. I drilled the hole oversize and tapped the hole for an oversize 1/2-13 bolt that is more secure than the stock configuration. While the work rest is stock, if the buyer wants, I will mill off the far right side of the work rest that wraps around the belt to allow quick belt changes like my new KMG has. I will do this at no charge and this mod would allow belt changes without dismounting the work rest. There are shop vac compatible dust collector ports on both the belt and disk side.
I have even seen at least one guy find the right form factor DC motor and convert one of these to DC variable speed.
This grinder a great deal for a newbie maker as there is a reasonable assortment of abrasive belts available in this belt size from TruGrit. Many affordable belt grinders are limited to belts available from Sears or Harbor Freight that suck.
Speaking of belts and TruGrit, included in this sale are the following new/unused belts:
4 Ceramic Alumina 60 grit
7 Ceramic Alumina 120 grit
14 Klingspor Aluminum Oxide 220 grit
7 Klingspor Aluminum Oxide 400 grit
There's also a half dozen lightly used belts (I threw away any questionable ones).
The new belts alone would cost around the asking price of $150.00 for the whole package including the grinder itself. There's also a couple extra Craftsman 8" PSA disks included.
Local pick up only as I don't want to deal with shipping.
Feel free to email or PM me with questions.
