I do this as just a hobby. Don't have a fortune. I had been looking for a 3/4 hp, 3450 rpm motor. I guess I could set up a double shaft and speed it up. You loose a lot of hp by doing that though. Thanks for the advice.It depends on what your plan to use the grinder for - if it's mostly used for profiling, then yes, it's too slow. If for finish grinding then it would "work" - sorta.
Your 1725 rpm motor with a 5" drive wheel gives around 2200 to 2300 SFPM belt speed. Rather than think about a new 1 ph motor, get a 3 ph motor and VFD. While if money is no object the expensive KBAC NEMA 4X VFD is a good choice, but that's getting close to $400 just for the VFD. For a hobby use (like myself) my suggestion would be this $60 VFD on Amazon B0BTCRP1LC..... ooops, I see then increased the price to $86. I ordered Nov 21 for $60 shipped. This one is a bit more expensive, but will take 120 vac input for a 220 VAC 3 ph output if getting 220 volt is an issue. Either put the VFD in an enclosure to protect from grinding dust, or as I did filters over the air inlets to help with metal grinding dust. I usually get 5 or 6 yrs from the NEMA 1 VFDs with inlet air filters, and never remember to blow out the inside with an air hose which I'm sure would help.
Here's an ebay item 375823148902 listing for a 56C 2hp, 3ph 3450 rpm motor for $171.35 shipping (plus taxes of course).
As other folks will tell you for general knife work, a variable speed grinder can't be beat. For 2 or 3 yrs I touted my 3 speed pulley setup as all that was needed. When I built the 2 grinder I went with a VFD, and boy there is no comparison. Try it, you'll never go back {grinning}
just checked on Amazon and it looks like the 2hp KBAC is not around $500!!! Way out of my league.
Just a hobby for me. I am up in age, and just want to learn a little about knife making.Loveless didn't need variable speed. We used to walk 5 miles to school, uphill-both ways, in the snow.
You can make knives with a file. A 1 X 30 belt grinder is a big improvement. A fixed-speed 2 X 72 will make you think grinding is easy after the first two options.
A variable speed grinder is a wonderful thing to use. A new heat treat oven is great, too. And a fiber laser for marking. And, don't forget an array of different buffers-so you don't even have to change buffs. Maybe an extra 2 X 72 also. Then, you need a CNC controlled milling machine. Annnd--- a bigger shop.
How far do you want to go? How much do you want to spend? Hobby or for profit? How far down the rabbit hole?
Careful there… it’s a slippery slope!Just a hobby for me. I am up in age, and just want to learn a little about knife making.
So very true. To old to go very farJust a hobby for me. I am up in age, and just want to learn a little about knife making.
