I think this is the most complete machine with all accessories and VFD
http://volf48grinders.com
ÜberGrinders ---- base price 2200$
include:
- Complete frame. Rotates 90 degrees, locks in either position, 3 receivers for positioning the tool and workrest arms to suit your preference. All adjustments are made without tools.
- Crowned, urethane drive wheel. Keeps the belt from slipping even under low tension, high torque operation.
- Pneumatics for belt tension. High quality Mead/Bimba regulator and cylinder.
- Überrest (Articulating work rest with steel table, vernier scale for accurately adjusting in 1 degree increments. Again, no tools required.)
- Platen/Slack Belt Attachment. Improved this time around to work better as a slack belt attachment with the removal of the platen via 2 screws. Also, new shop made wheels make the belt lie flatter against the platen than before, with less ‘puckering’. You’ll really appreciate this when using fine, flexible belts. (Requires a wrench to switch between platen/slack belt operation)
- Small Wheel attachment. (Small Wheels not included)
- Arm and hardware for mounting a Contact Wheel.
- VFD bracket for mounting your VFD to the grinder itself, or to your bench.
Volf48Grinders ----complete 1880$
include:
The main product I offer can achieve a 90 degree rotation and a variety of attachments can be applied. The whole kit weighs around 105 kg and it includes: the main machine, a straight grinding attachment (l=300mm), concave bevel wheel (d=250mm), 3 small rollers (d=15mm,28mm,34mm). A larger wheel (d=450mm) can be mounted as well on the main machine.
The product is crafted to a high standard. Thickness of the steel used – 3,4,6,8,10,25,30 mm. The body represents a tightly conjugate space framework. The supports sections are 25x25mm and 30x30mm. Steel used – C45. The large wheel is produced in Italy from aluminum and has a rubber ring running along its circumference, with hardness approximately 85 Shore units.
Its 1,5 kW engine runs on three-phase current and can achieve 2870 RPM. A frequency inverter controls the band speed from 7 m/s to 28 m/s. These velocities can be adjusted to the client’s preferences.
it is only a question of shipping and possible duties
