Hello Frontier Forge,
Welcome to the forums!
The sky is the limit as to what you can do for a motor and speed choices.
I have a few questions. Do you already have a motor? if so what is it? What kind of electrical power is available?...ie. 110V , 220V? Home work shop...or industrial building?
You really need speed options for knifemaking...in which you can get from a Variable speed motor, or from Single speed motor with step pulleys to change the speed.
I've surveyed dozens of makers to get a feel for common speeds....only to find that belt speeds vary as much as the makers.
But here are a few guide lines to get you in the ball park with your KMG1.
You should be able to spin the drive shaft on the grinder up to about 3500-4000 rpm for reckless rough grinding with very coarse grit belts...say 30-80grit. This speed is good for profiling, debarking, and gross metal removal. Then you should be able to slow it down to about 1000-2000 rpm for more refined work and finer grit belts...then as slow as 500-1000 rpm for finishing work. These speeds are strickly the rpm of the drive shaft of the KMG1. Consequently for this machine, the drive shaft speed is also the belt speed in ft/min...so if the drive shaft is running 1000rpm, then the belt speed is 1000ft/min.
If you need to get a motor, you can use about anything...however some will work better than others on this machine. I recommend at least 1hp....but encourage you to get 1.5 or more. In a single speed motor, I like the 1725 rpm frames better, and if you use a DC variable speed motor, I prefer the 2500rpm models.
Here is a picture of a step pulley setup:
I hope this answers some of your questions. Feel free to phone me and I'm sure I can answer about anything that might come up.
Sincerely,
Rob
Shop phone; 614/263-5656 9-5 EST
