DEllis
Part Time Steel Basher
- Oct 17, 2007
I have a question for the motor experts.
Here is my situation. I am off grid, and have solar power with a battery bank and inverter, and a small generator for backup. I am currently(pun intended
) running a 1hp 1750 RPM motor, and it has plenty of torque, but it draws my batteries down real fast.
I also have a 1hp rated 3450 rpm motor which draws about 1/4 of the juice.
My inverter has a digital readout so I can see how much draw each motor takes at startup and while running. The 1hp 1750 draws 500 amps to start, and runs at 160 or so.
The other motor pulls 200 amps at startup and runs at 42.
What would be the difference in torque between the 2 motors considering they have the same HP rating? That's assuming I have them set up to run the same belt speed(about 3000 SFPM)
I can't just swap the motor and try it as the 3450 is a flange mount and the 1750 is not, so any swap will require a complete rebuild of the motor mount. I'd probably just build a new grinder with the faster motor.
If anyone can shed some light on motor HP rating, torque and RPM, and the real world relationship between these, I'd be much obliged.
Thanks,
Darcy
Thanks,
Darcy
