- Aug 20, 2018
So I’ve spent the better part of three days moving all of my equipment over to my new house and I’ve recently run into some issues. My workshop at the new place is in the basement, and therefore has GFCI outlets. After running the extension cord and power strip, I found that my grinder immediately trips the GFCI, and my small Stinger vacuum does as well. I did several tests in order to isolate these devices and found that the power strip and extension cord are both fine and my issue isn’t related to amperage, as my setup is perfectly capable of running a 14 gallon shop vac and portable bandsaw at the same time. I did some research and found that steel dust could be the culprit, so I used my vacuum blower to thoroughly clean out the motor and VFD (even though they’re both totally enclosed and had virtually nothing in them) and still had the same problem. Both my grinder and vacuum work perfectly fine on regular outlets.
*the ground wires are also tight on everything*
Any ideas for what might be causing this?
