- Apr 3, 2011
I am pretty sure every grinder uses bolts to secure the wheels to the tool arm/platen and bolts are precision ground. I recommend checking multiple angles as well (not just from one side). Now given, this is a 2.5" wide wheel and this is the far side of the wheel but it's a .005" gap (checked w/ feeler gauges).
*update: axle flex is apparently a significant issue for any of the wheels
When I rotate the axel/bolt around I get this:
Fortunately I was able to use an indicator and bend the bolt straight so it's good to go now! I am thinking about trying a step bolt as those are likely more precise.
