- Jul 31, 2015
What is the process for replacing wheel bearings on a belt grinder? I smoked the daylights out of my tracking wheel bearings.
I just run a punch into it and tap them out from the inside with a hammer. They sit against a ledge so you can't just press them straight through.
so just insert the punch at an angle from the opposite side and tap it out? I assume i should alternate sides of the bearing so it comes out somewhat straight? also, what lubrication is needed if any for bearing maintenance? The bearings that are currently in there stated "sealed" so I don't know if lubrication is even possible? They did not last as long as i thought they should. My grinder does about 3400 sfpm and i have about 8 knifes, including handles, on this set.
One more thing to add they failed shortly after I sprayed them with WD-40 clean dust out from them. I figured since they're sealed that shouldn't be an issue but I've been wrong before, maybe even more than once
Compressed air is probably a better choice for getting the dust off of the bearings. If there's dust IN them, they're already done for.
