- Apr 27, 2009
I have a piece of 48"x8" aeb-l that is .100 I think. I'm going to have to send it out for heat treatment. I have heard that there are a lot of problems with warping. How thin can I take it before I run into trouble?
Salem, how fast or slow do you run those end mills and what do you use for lubricant? I need to redrill a couple of hardened AEB-L blades and try to enlarge the lanyard hole on some .187 thick 3V blades. The latter task is the one that has me a bit worried.I also do all of my bevel grinding on AEB-L after heat treat. It's not that bad, and certainly better than trying to fix stubborn warps. Sharp ceramic belts and gators to finish with work well.
I even drill my holes after HT most times with kitchen knives now, using 4-flute carbide end mills. Works well for me, although everyone has their own methods.
