- May 29, 2004
I am grinding a 10" chef's knife post heat treat using AEB-L. It was pretty dang straight when I started grinding but I am about 2/3 through my 60 grit grind and it has warped. I was dunking after each pass and alternating sides because of potential warping issues with this steel but it warped anyway. I may be able to grind the warp out if I am careful but I am wondering if I shouldn't try clamping it to a straight edge, shimmed so that I am removing the warp and then put it in my heat treating kiln. I use this trechnique to remove warps in the carbon steel that I heat treat myself. Is this a viable option? If so, what temperature should I use?
