Hey Vlahos, I think I understand a bit better now. Nice belt grinder you have, is it variable speed?
You can start with as coarse a grit as 36 for the bulk of the stock removal or you can start with 60 grit. After that you can work through 120, 220, 320, 400 and on all the way to 1500 and beyond if you had the mind to. You can stop at 320 or 400 for a nice satin finish, you can begin buffing after around 500 or 600 grit to work towards a mirror finish. Some makers skip a size between belts
(i.e. 60, 220, 400 then 500). You just always want to remove all of the previous grit scratches before you move on to the next grit.
If you don't have variable speed you can use the belts to slow your grinder down for the finer finishing belts.
With a belt grinder of the caliber you have you are miles ahead of me so I hope some of the other guy's in here will chime in also. -Guy Thomas
