Grinding First Blade
Hi All,
Well, after fiddling with patterns for a couple of weeks I finally settled on one and started grinding it out yesterday. I am fairly handicapped in that I only have a 1x30 Delta grinder so I have the choice of a narrow belt or a chinzy platen to lay the blade against. Makes it really difficult to get surfaces flat let alone hollow grind!
Anyhow, I took a 1/8 chunk of ATS34 and ground out the shape with a disc grinder then fine tuned it with the disc on my Delta grinder with 60 grit. After drilling the pivot hole (I'm making a folder) I then began the bevels. Right away I noticed that I wasn't removing much material from the middle of the blade. Sure would be nice to have a rubber contact wheel. Got me thinking about the Burr King in my buddy's shop in VA that I used to use years ago...
I decided to try the disc grinder and gently hogged out some of that middle area. Then threw the blade back on the Delta and smoothed it up as best I could. Mind you, I quenched the blade continuously but I am still expecting warpage in the heat treat. I figure every time you see brown or blue you're probably creating a stress area. I'm wondering if annealing the blade would help combat this?
Finally I ended up with a rough blade shape with main bevel and a false edge although the bevels are not very symetrical. I'll tell you, my hat is off to the guys who can grind these things out by hand. They're friggin hard! BTW, I'm no stranger to grinding metal having worked in a blacksmith shop and made lots of jewelry and metal sculpture so I was prepared for a challenge and I found one.
Couple of thoughts. I had a lot of trouble keeping the bevel lines straight and am thinking that a fixture like the one in Terzuola's book is probably the answer. I thought I'd give the freehand method a try first but it seems insanely difficult. I do have a knifemakers magnet that I got from TKS and that helped a lot but it was still not easy.
Another small problem was that I kept losing my point on the blade and had to reestablish it quite a few times. Also, the cutting edge area was very consistent until the last inch toward the tip when it starts to thicken a bit and I just couldn't seem to thin it to match the rest of the edge. Maybe I'm letting up as I reach the end of the pass but I was making a conscious effort not to. Any of this sound familiar?
I have a Jet attachment for my 1 horse grinder on the way so hopefully I'll be able to get a rudimentry contact wheel in operation this week. One thing's for sure, I'm really liking this!
Peter Atwood
email:fountainman@hotmail.com
[This message has been edited by fountainman (edited 01-14-2001).]
i have a 1x42 with a 8" disc i use the disc for just about everything including beveling that how i was taught.hardly use the 1x42 except for handle shaping...keep practising
ps you are grinding with two blades tang to tang ,it helps give you something to hang on to (holding on to one blade while you grind the other)i used to grind folder blades just trying to hold on to the half or three quarter of an inch tang but now igrind them back to back
i keep grinding and grinding and it is still too short!!
After watching Bob Ogg's video I think folks have the wrong attitude about blade grinding. I started on an elcheapo bench grinder with two rocks, extremely coarse and coarse. Naturally once I started getting knife mags and books I wanted a belt grinder and managed to come up with the money for one after going thru some cheap small belt sanders.
In the video, Bob grinds on a big bench grinder with a 10 or 12" by 1 1/2" rock. Since I saw that I started looking and found those size rocks are not hard to get, and on Ebay, quite cheap.They come in several grits too.
I think this would be a good way for new makers to start without having to spend $1000 on a belt grinder. I'm thinking about setting one up myself for all the rough grinding. I realize grinding rocks can explode, so safety is a must!
Just something for new folks to think about.
Take care!! Michael
Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!
http://www.nebsnow.com/L6steel
Buzzards gotta eat, same as worms!!!
Grinding was hard for everyone the first few times. It still has its moments from time to time. Hang in there though, it gets better and better.
BTW, since you didn't mention any blood, you may need to try harder...
Good luck.
Jerry Hossom
www.hossom.com
The New Tom & Jerry Show
Peter,remember,beginning knifemakers dont make mistakes,they just do a lot of mid stream design changes.Seriously,hang in there,it just takes practice,all knifemakers have had the same problems in the beginning.
MJH
Well thanks for all the encouragement. I decided to take the day off from grinding to unload my kiln, hang out with my woman and drink beer.
But tomorrow I'll get back to it. I've got the week off and about 18 inches of steel left so I might just come up with a decent blade yet.
I'm actually thinking I might be better off with a file to straighten out the woes on my first blade. I tried it for a couple of minutes this morning and was able to pull one of my bevels down to where it should be. The shoulder of the bevel still looks like crap but I'll hang in there. I just keep remembering that the first piece of wallpaper that I hung and the first pot I threw were terrible too. I thought that I might be ahead of the curve on this one though.
Peter Atwood
