For guide blocks, I took two pieces of 3/8" D2, about 5" long, and drilled 1/4" holes in them about 1/2" from the ends. I tapped one for a 1/4 20 bolt. Then I used my disc sander to grind both sides square. Then sanded them nice and smooth with a 320 grit belt. Rob has them right now for heat treat. All you do is slide the blade between them till the edges are where you want the ricasso or plunge cut to be. I do all my flat grinding on a 6 by 48 sander.I have the luxury of a Wilton belt grinder, so I actually start the flat grind by taking off alot of steel on it and then moving the the 6 by. If your platen is square on the edges, you might want to take a good file and roll them some. Then you just put the blade on the sander with the guide block against the side of the platen. It keeps you from getting Wandering Ricasso Syndrome. Something I tend towards alot. I also eased all the edges of the guide blocks except the two that meet the knife blade. That way theres nothing sharp to get into the contact wheel if you're hollow grinding with them. Just be suure to use some real hard bolts so you can get them good and tight. Hope this helps you out!! Take care! Michael
<A HREF="http://www.nebsnow.com/L6steel
"Always" TARGET=_blank>http://www.nebsnow.com/L6steel
"Always</A> think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!"
