Before HT you need to relieve the internal stresses created during grinding.Heat the metal to critical temp (non-magnetic) and allow to cool on a fire brick.Repeat this one or two more times.The stresses should be gone.Then heat to just above critical and quench as normal for the steel you are using.Immediately after quench place the blade in an oven heated to 350 for about and hour.Let it cool to room temperature and repeat the temper again ( at the desired temper temp if you know it,or 350 as a guess).Clean the blade up and polish,being careful not to overheat the blade when finishing (and thus ruining the temper).
