I am relatively new to knife making and I have a question about whether or not you should heat treat your blanks before grinding them? For my last couple of knives I have been using farriers rasps which I flattened the teeth, annealed, shaped into a blank, ground the bevel, then heat treated.
My thought process is that it is going to be a pain to grind on hardened steel and I should take advantage of the blanks softness while I can. Is this correct? Is there an advantage to heat treating the blank while it is still uniform in thickness? I realize that thinner metal will get hot/cold faster than if it were thicker metal. How much of an affect might this have on edge retention since the edge is cooling faster than the spine on its way to the quench bucket?
Any little nugget of information about the steps you take to make a knife, or the heat treating process, would be much appreciated.
Thanks for your time,
Trogdorr
Trogdorr
