Grinding Question
I have a couple of Hi knives with very long ricassos. Just want to extend the edges 3/4 of an inch or so. I planned on doing this on my 1X42. Anything I should watch for? I was specifically worried about overheating the blade. If I reground this much could I screw up the temper?
I was going to do the work with heavier grit 1" belts and then clean up with high grit belts and a leather belt on the 4X36 with belt lifter so I can get a slack belt to work with..
Thanks for any advice or information.
Norm
Norm
Hi Norm:
Use new belts and go real slow.
Sarge grinds a lot of blades. Maybe he'll show up with the best answer for you.
Most likely not worth your time and trouble Norm. Remember that the kamis zone harden their blades based on the existing edge/blade profile. Wouldn't surprise me a bit if the metal in the ricasso area you're talking about grinding is already too soft to hold a decent edge. The job of the metal at the blade/handle juncture (ricasso) is to be tough and resilient, not necessarily hard. A better use of that "real estate" might be to incorporate a choil.
Sarge
What Sarge said. Etch first. I've never seen a hardened zone extend into the ricasso area in an HI blade.
Thanks guys, that makes sense. On the one knife I have, I do wish they had ground the blade profile all the way back properly and then hardened. It's only about an 8" blade overall, so why leave a 1.5" ricasso? The blade swell after the edge does make it fit easier to the scabbard I suppose, but that seems a poor reason to leave that much unused steel.
I plan on putting a choil in on a couple of the sarge knives and Kumar kardas, but this is on a knife with a guard (a sherpa crow knife), so a choil would look kind of silly.
Although, I plan on changing the guard a bit so this may work out after all.
Thank Sarge and Dave for the good info!
Best,
Norm
Agreed...it would be cosmetic only. I'd hold off changing it though as they sometimes know what they are doing...strength, a choked up grip, safety for pulling it out of a zombie...whatever. Once gone, awfully hard to put it back on.
