Welcome BamaNoob. Fill out your profile so we know where you live and a bit about you.
There might be a smith in your town who would help you out.
Non-magnetic is a state above1390°F in steel. It returns to magnet as it cools back down. This is a way to check the temperature of the steel when doing HT in a forge.
Tempering of a knife is done between 350°F and 450°F. The surface will change color as it heats up. Blue is around 500°F and shows that the temper has been affected at te edge. As you continue to grind, you may grind away the blue color, but the change to the temper is permanent (unless re-Heat Treated).Carefully grinding the edge back a little farther while keeping it cool may get past the damaged temper area if he edge only had a little blue area and it wasn't all turned blue.
Avoiding ruining the temper and making a soft spot on the edge is why sharpening of a woodworking tool or knife is always best done by hand on a stone.
When grinding, the thin edge can become several hundred degrees in a fraction of a second. To prevent "burning the temper" of an already hardened steel tool or knife, you have to dip it in water pretty much every pass to cool it down. Also, use a gentle hand and take material off very slowly.
Your marking knife will probably function OK, but will need re-sharpening more often. If it was a whittling knife it would be useless.
