- Jun 28, 2012
What is usually preferred on Kitchen Knives, Hollow, or Chisel Grinds?
Any feedback is appreciated, thanks.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Very broad question, probably best answered a bit more narrow.
Definitely not hollow and definitely not chisel grind (unless you're talking traditional Japanese knives...but even then it's more complex than a chisel grind).
A very slight, symmetric convex grind is preferred by some....others prefer a true symmetrical flat grind with a convex edge as Jason has described....still others prefer a full flat grind spine to edge. I'm sure there are other similar grinds that are preferred as well.
What I feel is more important than picking from those grinds, and Jason eludes to this, is that it needs to be thin. 0.010" or less at the edge pre-sharpening is best with a spine somewhere around 0.10" thick at it's thickest....a 0.20" spine even with a 0.010" edge is still not a good cutter. These are all chef's knives specs...other knives will vary depending on use.
And since we're so thin....it has to be ground well with no "holes" in the grinding. "Holes" are what I call overgrinds along the edge where either side is thicker and the "hole" is thinner. As you sharpen into this section you will see the hole and it becomes an issue.
Now, if you want to get fancy, smancy...a very slight convex in an asymmetrically ground knife can be fun too. Most traditional Japanese chef's knives (gyuto's) are ground asymetrically with something along the lines of 30/70 or 40/60 grind.
wow. So, am I reading you correctly, that the spine is slightly thicker than 1/64"? Also, what about a paring knife? What thickness at the spine?
I agree with watercrawl as well, I would also like to add that if you make a large chef knife and start with a .1 inch spine and a do a full flat grind and full distal taper, you will end up with a knife that flexes way too much. with such thin stock a very gentle distal taper or only tapering half of the blade helps alot.
.. I've heard hollow grinds being used on Kitchen Knives, which surprised me a bit, ..
