- Jul 12, 2020
I have two mini griptilians, one 555-1 and one normal 556. In both knives, when I have the knife open, and then I fold it closed, the the blade is loose and easily folded the first 4/5 of the way closed. But then the blade becomes harder and harder to close (not difficult to close but you can feel more force is required). This increased tension comes solely from the blade and not the lock bar because I can feel the increased tension even when I pull the axis bar all the way back so the blade never touches it while closing.
On my 555-1 it is much more noticeable. Sometimes the blade does not even close all the way and remains a few mm out even though the axis bar with omega spring is pushing on the blade to close.
I know the pivot is not overly tight because the blade can fall shut 4/5 of the way with a light wrist flick until that point at which I need to push it in myself. Also if I loosen the pivot any more, significant blade play will be noticed.
I have tried cleaning the knife and re-lubricating the pivot and washers to no avail. Are there any other suggestions? This problem seems to be only present on my griptilians as I feel no difference is tightness throughout the entire closing of a 940 that I also own.
