- Nov 8, 2015
Does anyone happen to know the grit of this stone?
I've seen these selling eBay for triple that. It felt really course but haven't tried it yet. Anyone know of similar ones around 400 grit that are relatively inexpensive?
Both of the stones above look closer to 100 grit.
I have a Norton jb8 combo, 100/280. The 280 side is much finer than the above.
No; this shows that looks can be deceiving. The ACE stone is much finer than that. I have two of them, and they grind more equivalent to ~320, or finer with some use. Very similar to the 'Fine' side of Norton's Economy stone (in SiC), which is also much finer than 100 grit. Norton rates their Fine SiC (Crystolon) roughly between P320-P360 (as compared to wet/dry sandpaper). In my own use of it, it compares very closely in the finish to 320-grit wet/dry. In fact, to the OP, that might be a pretty good way to figure out what grit finish your stone is grinding to; use varying grits of wet/dry paper on glass or stone, and compare the finish left by each to the finish left by the stone. The hard backing under the wet/dry paper will most closely emulate grinding on a stone.
David
It felt really course while sharpening my knife. Do I need oil or is it an option if need finer cuz I read it is option of need finer. Either way it's put a hair shaving edge on my delica that doesn't look polished but doesn't look toothy either
