Thank you Samurai.
Thank you David.
Thank you Mo2.
This is is very clarifying.
Its like a equation without rule.
Angle~finishing grit~steel (hardness, heat treatment...)~cutting tasks (in what the blade will be used)~kind of cutting (chopp, slice).
First I thought that edge holding was all about sharpening angle. Then I thought it was about grit finish. Then I discovery steel hardness (what help in edge holding by the way). Now it’s clear (or a bit more) for me that everything have influence on edge holding.
There is a world of knowledge that I must to learn.
When I was sharpen my first knife I thought that was just rubb the blade on top of dual side sic stone. Never had one sharp or honed.
I read that for general purpose 600 grit is a good choice. Then I use to work my blades in it and strop after done. For my eyes, 600 grit diamond stone with strop after it looks like many factory edge visual, so I presumed factory edges like spyderco could be “cloned” (without being pretentious) with my tools if I work that way. Maybe until 1200 and strop. That way I still can see the finer scratches and get a razor knife.
I don’t dislike polished edges, but I can’t find a purpose on my every day use. Maybe on a kitchen knife, but I’m not a MasterChef.
About degrees I’ve use 10dps with micro at 20dps. Just for testing my skills. Then I read a topic about grinding above the bevel and what low angle does. Now when I pick a very used blade from my parents, sister, cousin, neighbor... that have about 1mm thickness above the bevel I grind it to mantain the cutting ability on that blade but no micro. I know I can be changing the blade geometry, but is what I can do with the tools that I have. And then I just put 20dps. But there is a theory that said lower angles increase edge holding and it make sense when you take the principles of aerodynamics. Just thoughts.
About the grit finish, beyond the beauty is the efficiency. When I sharp a knife for my sister, I would like it last longer as possible without taking into account the types of use because when you hone a knife for others you can’t control what they are cutting.
Im not a professional, I’m just a perfectionist enthusiast.
By the way if the knife belong my mother-in-law I would like it last forever. Or never.
Thank you all. I really appreciate your work.
