Seriously is there anything sharpening related you don't know? And thanks for the tip I will give that a tryI would suggest taking it back. It will work but you are going to eat blades up because of the belt speed.
Sharpening on a belt sander is not like sharpening on a stone. Some will argue this but I would never recommend running a progression of belts. Set the bevel with a 120 grit belt, deburr then polish the edge. This not only yields similar results to what the factory does but it also provides some of the best edge retention in everyday tasks. Personally, I use a Norton Blaze 120 followed by a fine scotch brite wheel to deburr then a surgi-sharp leather wheel to polish. I would put this edge against anything with confidence.
Now what if somebody was to make a 1x30 wet grinder that was adjustable speed or just able to go a lot slower kinda like if tormek made a belt grinderI would suggest taking it back. It will work but you are going to eat blades up because of the belt speed.
Sent from my SAMSUNG-SM-G870A using Tapatalk
