Grits on sharpening stones ???
I am interested in getting some superfine stones to get a better edge on my knives. However after searching this forum I have become a little confused with how the grit of a stone is measured. For example a DMT stone might give you as fine an edge as a Japanese water stone even though the water stone has a much higher grit number.
If the grits arn't standard is there a better way to compare different stones?
Josh, I like diamond stones because they cut the more abrassion resistant stainless steels as well as high carbon steels. They are also easier to use and maintain (i.e. no oil; stay flat). What you typically find with diamond stones is that they cut more aggressively for awhile then break down to a less aggressive grit for a very long time. I think DMT has Very Course, Course, Fine, and Very Fine. I was using the very fine more before the fine broke down to where the very fine started. I don't use the very fine much anymore as it has turned into more of a polishing stone. Wait, now I'm getting confused
If you buy one of each grit you will have more choices. Different steels and different styles of knives require different edges. If you want to polish your edges the very fine will do that after it gets some use.
Most importantly, find what works for you and your knives.
In my opinion diamond stones are much coarser than advertised. Don't get me wrong I like them but a superfine green DMT benchstone is coarser than a 1200 grit Japanese Waterstone. I don't get even close to mirror edge. They do cut fast and they stay flat unlke waterstones.
Roger Blake
Hi Josh, Cerulean gave you the best possible data. But: there is a but =>
up to grit # 280 grains have been measured using standardized sieves, according to ASTM. Above that number, manufacturers used their "marketing phantasy" to indicate "grit" size.
Most modern abrasives are now calibrated in Microns, which are comparable as long as they do not "break down".
Some traditional hones/compounds: japanese waterstones, belgian "blue", "green" rouge, etc, break down easily and so have a "not well defined" grit size.
BTW: to get an excellent edge, you do not need a superdupermaxiatomic fine hone. A tiny bit of (micro-)serration makes a VERY aggressive edge and stays longer so than a fully polished edge.
Happy sharpening
Ted
<font face="Verdana, Arial" size="2">Originally posted by ZUT&ZUT:
Happy sharpening
</font>
I know that this is the conventional wisdom here, but I don't agree with this.
I sharpening my knife on my Edgepro, I went up to 600 grit stones, and got an acceptable edge, but it would only shave arm hair with a lot of effort, and not slice cut paper very cleanly.
I then put in the 3000 grit polishing paper, give the blade 20 strokes per side, and look out! I now have a mirror polish with which I can (and did) shave my arm, my chin, and can both push cut AND slice through paper with almost no effort at all.
Now, maybe paper is not a conclusive test medium, but everything that I have ever sharpened cuts and slices much better with the mirror edge given by the very fine polish.
As always, your mileage may vary, but this seems to directly contradict conventional wisdom. Am I missing something?
Swede:
The reason your 3000 grit edge cuts better is because of the tests you do! A micro-toothed edge may not shave hair well, but it will cut leather, rope, cardboard, etc. a lot easier than a polished edge.
Polished edges excell for push cutting, and that is what you do when shaving hair. Slicing cuts, however, are best made with a micro-toothed edge.
I still think that polished edges are more durable, though. Microteeth are very small, and wear quickly. A polished edge, especially a polished moran edge, is a thing of beauty!
"Come What May..."
Thanks Crayola,
I'll try some other things to cut and see how it goes. I agree with you about the polished edge, there's just something about being able to see yourself in the polish...
Very polished edges can be achieved with ultrafine white ceramics followed by stropping with green chromium polish. I routinely put this kind of edge on wood carving knives and gouges, but only because that kind of edge works best for push cutting in wood. The angle of the edge and blade geometry can also effect edge performance. The optimal edge depends on the knife, the steel, and the material to be cut.
I agree with those who prefer a slightly roughed up edge for a generl purpose knife. It will push cut well, and slices most materials better than a highly polished edge.
Once you get to the finer abrasives, sharpening technique is probably much more important than the exact abrasive grit being used. You should be able to maintain edges very well with only two stones, a 'medium' and a fine. You can add an ultrafine stone if you like. I like to strop all my knives, even if I only put a 'rough' edge on them. 'rough' for me is a medium ceramic stone.
If you do not let the edge deteriorate badly during use, you should not need to use the rougher stones except on the exceptionally dull knife, or to reprofile a knife with the thick and profile or asymetrical edge bevel angles.
The grit sizing for ceramics is different than Japanese water stones, or for diamond stones. I agree that comparing the average particle size in microns would help a lot, but as pointed out, some materials break down to smaller and smaller particles quickly.
Fine, and ultrafine diamond stones make a nice pair of stones, or medium and fine ceramics, or a 1000/4000 grit combo Japanese waterstone. They all work a little differently but will yield similar edges although the diamond stones will leave the roughest final edge. That is not necessarily a bad thing, a skinning knife will work best with a rougher edge.
I thick ceramics are the cleanest and easy to use stones to use. But I also like to play in the mud with waterstones sometimes.
I have not yet used diamond stones on my knives, but many here really seem to like the DMT products. The word in woodcarving circles is that these cut too fast, and leave a relatively coarse edge (bad for carving) compared to ceramics or waterstones. I have seen a graph produced by Norton which claims to 1200 grit diamond stone is the equivalent of a 6000-8000 grit waterstone in final polish, and cuts much faster. I think there is something VERY wrong with that chart.What I find strange is that folks who really do need ultra high polished edges do not seem to use the diamond stones very much. I think Beam is right about the fine stone being rougher than a fine ceramic, or maybe even a 1000 grit waterstone.
BTW, shaving and paper cutting is only the Beginning of getting a nice edge.
A gratuitous appeal for more gadget-less sharpening:
I really think learning to sharpen freehand will teach folks much more about how to sharpen than using angle fixing systems like Edgepro, or V-sharpeners. I took me a year of daily effort before I started to be able to properly sharpen my woodcarving tools. What used to take hours can now be accomplished in a few moments. It takes a while to learn, and can be very frustrating a first, but once you 'get it', you will be able to put great edges on almost any knife with any kind of stones.
As with many skills, having the 'best' tools is much less important than having the knowlege and experience to use the tools you have well.
Paracelsus
[This message has been edited by Paracelsus (edited 05-12-2001).]
