Don't put oil on the tang/axis bar. Just the act of the bar moving across the tang will keep the area free of corrosion. If you let the knife sit for a length of time then yes, oil it. But you will have to clean it up before use if you do that. Oil just causes problems when it's in that area.
My Super Freek wasn't as smooth as other Benchmades I have, so after a couple of days of use I did my normal blade removal (no need to completely disassemble an Axis lock knife). One of the washers had a burr on it. I took care of that, and flattened them a little on a stone, and now it's one of my smoothest Benchmades.
Sure, you could say that the knife shouldn't have left the factory like that, but it's a popular model and sometimes things happen. It was an easy fix and worth it. It would have worn the burr of and flattened the washers naturally, I just helped it along a little.
