If you do get the Grizzly, then you may find as I did that things need to be worked on a bit to make everything run.
If you drop by my Grizzly webpage :
http://eastof29.tripod.com/daqotahforge2/id7.html
You will the photos I took when I got mine . I talk about a problem I ran into with the Platten and the fact that the holes pre-drilled to bolt it in place didnt actaully match up.
Also I have a struggle with the use of different size bolts and the directions that come with the Grizzly that seem to have been a translation from some un-known tongue.
I have the 8 inch wheel and have just learned to work around the problems you have with the 8 inch and running into the motor when you grind to the left hand side.
I have strong views about placeing the contact wheel over the end of the bench or table so that there is nothing under it. I made a huge error when I bolted my grizzly down with the spinning contact wheel above the table....this placement has made use of the full contact wheel too hard as I keep running into the table with the blade.
I also get my belts from Pops....he has helped me save a ton of money, and the 3-M belts work good.
The Grizzly Buffer on the left of the grinder motor is a dream...it has really helped me finish my blades well...I use two different buffing pads, a harder one to cut the scratches, and a soft one to put a mirror finish on the blade.
