Joseph Bandeko
- Dec 9, 2021
So I was experimenting with some different things trying to come up with a better heat treating method and stumbled across this...
(Thus far I’ve only tried it with simple carbon steels but I’m sure you could modify it slightly to work for other steels as well)
So here goes, I heated the steel up as slowly as possible to 1725f (very important to go as slow as possible here) then soaked at that temp for 30 minutes, then I pulled the blade out of the oven and put it directly into the tempering oven set to 650f, then I did three 45 minute cycles like that in the oven, with a cryo cycle in between each temper cycle.
Using the method above I was able to reach a final HRC of between 65 and 69! (depending on the steel I used) and the blades have amazing toughness as well, I mean just outstanding toughness!!
I can’t wait to hear what y’all have to say about this new break through!!
