Initial Survey:
Last Saturday I took my Ganga Ram special out to chop down an ash tree. My friend had estimated it to be 12 in diameter. The GRS has been quite efficient in my hands and I did not expect it would take very long to bring down a 12" ash tree. The tree turned out to be a little bigger than described. I put my khukuri up to it and explained it my knife was overall length is 21 and the tree is thicker than the overall length of the khukuri. As my friend put it 12 was based on the part that he could see above the brush. Being the fool that I am I started chopping away at the tree.
Working on the Tree:
Progress with the GRS went pretty fast initially. I had wanted to minimize environmental damage and did not chop down many of the smaller trees around me. As a result I could only get full force chops from two positions. The bark was easy to chop through and I tried to remove enough material for so that I would have enough clearance as I approached the center of the tree. The GRS suffered its first major set back after a few minutes of chopping. The knife glanced of the side of the tree and struck a rock. The blow was pretty well full force. I was surprised there were no sparks but the rock was well marked. The tip of the GRS was severely dented. The damage consisted of a semi circle starting at the tip and had a radius of 0.375 in. The GRS was the only khukuri I had with me and I had no way to work out the dent it had to continue chopping. The damaged tip was not further damaged even though I did some more chopping with it.
After about 45 minutes of chopping I was 40% through the tree. Aside from the tip damage I had no problems with the khukuri or me. I was not very tired from using the khukuri and my hands had not developed any hot spots or blisters. Unfortunately I had gotten lazy and did not leave enough clearance for the khukuri so that I could remove wood effectively. I guess my fingers must have gotten tired over the next 30 minutes. I must have allowed the knife to slide around as I my hand started developing hot spots. I went and put gloves on. Progress had also slowed down considerably.
My right arm and hand got tired soon after putting gloves on. My right hand developed a blister along the bottom of the pinky and top of the hand. I also discovered about this time that I could chop just as efficiently with my left hand as my right and that my backhand chops were almost as good as my forehand chops. The khukuri also turned out to be painful to use with two hands. Vibration is severe on hand holding the rear of the khukuri. With one hand I did not notice any vibration even when chopping with the tip of the knife. Somewhere along the line my friend relieved me and did about 15 minutes of chopping, mainly to improve clearance.
The tree started to lean and make cracking sounds about 2.5 hours of chopping. At 2 hours 45 minutes the tree went over. Every time I heard creaking or a warning from my friend I would bolt from the tree during the last 15 minutes. When the tree finally went down I was had bolted 30 yards from it.
The tree was elliptical where I chopped through it. The major axis is 22 and minor axis is 19. This is the biggest tree I have ever chopped down. I am wondering if there is a Guinness world record for the biggest tree to be taken down with a single-handed knife.
Analysis:
A saw would have been better for a tree this size. With a saw the amount of wood removed (saw width) would have varied with the diameter squared. With chopping the amount of wood removed varies with the diameter cubed, since the blade needs a sufficient clearance angle.
Except for the encounter with the rock the GRS was undamaged by heavy chopping. There would quite a few blows where the edge of the khukuri was exposed to a great deal of stress. This usually occurred when the khukuri bounced of top of the V clearance and embedded it self on the opposite side. When I could I would twist the khukuri out when it was embedded in the tree. The knife was still relatively sharp after the tree went down. It would even scrape a hair or two off my arm. Definitely not shaving sharp. I was very impressed that the handle went through the ordeal completely undamaged. Bad blows, of which I made many during this session, that cause the knife to vibrate excessively sometimes result in cracked handle.
I dont know what to make of the rock impact. By hammering on the chakma I was able to peen over the severely folded edge and cold work much of the material to its original position. The damaged diameter is now only around 0.25. With a bit more work I think I can fix the edge up more. If the edge had been harder it would not have folded over as badly. On the other hand the tip might have broken off completely if the edge here is harder. I will most likely nip about 0.125 0.25 off the tip. The tip will be thicker but much stronger. Previously I had put a gash in a chain fence post with the knife further back along the edge where it is harder with no significant edge damage. I am curious how a blade that thickens up faster such as on an Ang Khola would have faired. The design favorable to make the GRS a good felling khukuri makes it less durable. Anyone have any experiences?
It is important to leave sufficient clearance with chopping implements. I had neglected to do this and it hurt my efficiency as I went deeper in the tree. The knife was unduly stress as well. The knife bounced of one of the V faces and wedged it self of the opposite side.
Will
Analysis:
Will
