- Apr 27, 2009
I am a welder and a AWS certified welding inspector. I am setting up my shop and have plans of working on blades as well many other projects. I have a Esab caddy Tig 2200 that will allow me to program a pulse down to 400 times a second. This offers me a lot of control and very low heat inputs. I had hoped to use this for 3 things.
(1) Adding tool steel such as CPM M4 (others may be a much better fit) to cutting edges of tools such as axes.
(2) Adding overlay of stainless or high nickel alloy. This could eliminate the need for a forge weld, create an interesting etch pattern or add performance or corrosion resistance.
(3) Allow the addition of mixed alloy "Mokume" type alloys to be added to a blade or tool post heat treat.
I would assume most of these techniques would require the use of high nickel alloy filler metal. I have a good working knowledge of metal working but would definitely not call my self even a good armchair metallurgist. Are there reasons why addition based techniques cannot be used effectively in a basic shop setting?
Also does anyone else use welding in any stages of knife making other the welding on guards?
