I soak the blade in a Ferric Chloride solution for about 15-20 to etch the surface to a flat matte.
Thanks for your reply psriley.
Back to the Gun Kote question. Sorry about the side question. I think Chris Reeve uses Gun Kote on his fixed blades. I have one of his knives and the finish is very durable. It will eventually wear in spots, and scratch if you really work at it or are abusive to it. I used the Chris Reeve knife hard in the field and the finish did its job. I think the key is following the manufacturer's recommendations for surface prep. Depending on your handle design and materials you use you may be able to blast the blade and re-coat it after years of wear if you wish.
I think it is a good way to protect high carbon tool steels from corrosion. I would use it if I had a blast cabinet to prep. the surface. Maybe some day.
