- Feb 23, 1999
I have one of the early Guntings. I am enamoured of this knife and use it as my daily carry and utility blade. As a utility blade it is often called into service to cut apples or other foodstuff. It is carried in my pocket in a custom Skunkworks pocket sheath so it is regularly exposed to pocket lint.
As I was idly playing with the knife this evening I found that I could unlock the blade with just light thumb pressure on the back of the ramp. I locked and disengaged the knife this way at least 10 times.
I got out my drone to compare the two and locate the problem. The liner on the back of the drone travels over halfway through the open space when I lock the drone. The liner on my carry knife was traveling only a small fraction of this distance and barely engaging the locking mechanism. I am sure that the knife was not doing this when I first purchased it and put it through its paces.
I got a thin screwdriver and pried on the liner. Now it travels about 1/3 of the way through the open space and engages the locking mechanism solidly. Perhaps the liner was glued in place by gunk, or perhaps the spring is fatiguing.
I dont intend to return the knife unless this problem becomes worse. I like it too much. But I am going to be aware of this failure mode and check the lock before I go stabbing any tires. Other Gunting owners may wish to periodically check the travel of their liners also.
