The gunting is a terrific utility knife. The handle gives you a lot of grip, and the ramp makes it easy to choke up on the blade. The blade comes super sharp, and appears to be very tough and have good tip strength. I really like the ergonomics. The compression lock is very nice.
I wouldn't say the knife is small. The handle is big, and the blade is a decent size. However, the ramp prevents the blade from going more than about 2 - 2 1/2" into things.
The kinetic opening feature is really cool. If you get a gunting - make SURE you get a trainer. The kinetic opening is so cool, that you'll try it on all sorts of things. Unfortunately, with the live blade, often the things on which you try it out will require a trip to the emergency room.
That being said, I just traded my gunting for a civilian. Why? I don't have a trainer. I know for a fact that I would eventually get myself good in the leg or arm. If I could afford a trainer, all the tapes, and had enough time to make use of them all, I would still have it. However, for now, I need something a that requires less training.
I did not like the carry posisition with the clip at all. The darned horn sticks out a couple inches. In the front pocket of jeans, it'll ocasionally catch on things you pass by, and sometimes open partially. I found that it was most comfortable in my back pocket on the right side - that way the horn faced in and didn't stick out. I doubt you could carry it in the waist band, unless you wear some kind of very different pants, and even then, it would be difficult to sit down without it sticking out. I almost wish it was tip up, so you could pull some emerson "wave"-like openings.
Overall, I like the gunting. Get one of the nifty break away sheaths for it, and all the other accessories, and you'll probably get hooked permamently. Problem is, the gunting runs about $115, the trainer $115, the tapes $99, the sheath $? (can't remember, seems like $25 or so), etc. Nice knife, very useful, but I can't think of a situation I would need a non-lethal response to that couldn't be covered by pepper spray and a lot of running. If you're a LEO or a bouncer or something similar, it could come in handy.
If you're looking for utility and comfort of carry, go for a vesuvius, a pioneer II, or one of the benchmade axis locks. The gunting is a really cool knife, but without the training and accessories - spent most of it's time on my desk and not in my pocket.
-- Rob
PS - I did learn a little about pressure points, though. D@mn, does it hurt/sting/make things go numb when you hit the right spot. Amazing.
Me fail english? That's unpossible!
