Gut Hook Question
I built a gut hook and I'm having difficulty getting the inside of the hook as sharp as I think it should be. Anyone know any tricks
for accomplishing this? Thanks for any suggestions are help.
Steve
Steve Smart
have the same problem.Wrap wet or dry silicone carbide(The black stuff)sandpaper around a dowel of the right size. there is a round diamond hone like a steel availble at Bi-Mart store around here.that works the best yet.I'Ll see if I can find the manufacturer.
TJ smith
I use a 1/4 inch round file. This is not to be confused with a "rat tail" file. These are used to sharpen chain saws. For a finer edge, wrapping a dowel rod with sandpaper as mentioned in another reply works as well.
One word of caution. Don't even get the gut hook close to a buffer, you are asking for trouble. If you need to buff the area around the hook, you can use the small 1 inch diameter buffing wheel on a Dremel tool. You can find these in most Wal-mart stores believe it or not.
C Wilkins
