Have been thinking about making a H frame forging press of about 24 ton.
I have some issues I need to ask some experts about first.
I only want to make this once and I do believe in over kill so there is no regret.
I have a small shop where I do my blacksmithing in.
So I need to make as compact as possible but as powerful as I can with space and budget limitations.
I have some 6x6 H beam that the flanges are .450 thick and the web is about .315 thick.
I have some 3/4" thick grader blade that I could use to reinforce the outside web of the beams if need be?
I plan on making the base and top frame inserts with pieces of the 6x6 Beam, reinforced with the grader blade. the cylinder mounts and top die holder(s) would be made from what ever the cylinder tie rod slot opening would allow maybe like 1.250 wide. ( proposed cylinder would be 5x8 or 10")
Is this H beam be acceptable to make the frame with?
I need a small of footprint as possible
Also thinking of having the cylinder on the top and not the bottom, only draw back I see to this if it fails and sprays fluid down on the hot work?
Please anyone chime in on your ideas or flaws that are possible or that you have run up against I need help with this. I have read Dr. Batson book and studied it carefully.
thank you
Ron
thank you
Ron
