I'm now curious if the austenite-to-martensite cold working transformation could be capitalized on with European-style tensioned/peened scythe blades. They're typically made out of a steel like 1080 and tempered down to ~45RC with the body of the blade drawn out in hot forging to about 1-1.5mm thickness then tensioned by cold peening the span of the blade, giving the blade its required rigidity. The blades are then beveled through cold peening, drawing out a thin edge that's then honed with a stone. By comparison, American, English, and Nordic blades are typically heat treated around 55+ RC in similar steel and beveled by grinding, with the body having been given one or more corrugations for rigidity, and the span of the blade usually being a bit thicker than Euro blades. The difference in edge-holding ability between the two camps is huge in my experience, and it makes me wonder if the Euro type could compensate for its otherwise soft heat treatment by exploiting that sort of transformation?
