IIRC, H-1 will actually get "stronger" as it gets used/sharpened overtime.
Any steel will bend to 90 degrees, depends on the geometry and the hardness. Also, with the same geometry, every steel will flex the same amount, it is when you get beyond this range that you get into bending or fracturing, depending on hardness. Bending is for strength (hardness), not toughness. Toughness is impact resistance.
If it gets harder the more it's used/sharpened, is it that the H1 at the edge is softer at the surface, and as it's worn away, more of the harder, inner steel edge is exposed? Because it doesn't seem likely that just the action of the sharpening itself would be enough to work-harden it.
Jim
edit to add:
I was using my SE Tasman, and accidentally hit the table with the tip. The fine tip bent a tiny bit, and I used the white Sharpmaker rod to lightly try to work it out. Now I can't tell anymore that the very tip had actually bent. Either it straightened out, or an almost imperceptible bit came off, but the tip looks no worse for wear. So it does bend rather than chip.
Jim
My guess it has to do with molecules, protons and crap.
Work hardening, strain hardening, or cold work is the strengthening of a material by, macroscopically speaking, plastic deformation (which has the nano-scopic effect of increasing the material's dislocation density). As the material becomes increasingly saturated with new dislocations, more dislocations are prevented from nucleating (a resistance to dislocation-formation develops). This resistance to dislocation-formation manifests itself as a resistance to plastic deformation; hence, the observed strengthening.
if this steel work hardens wont that cause the metal to become more brittle.am i incorrect in thinking work harden goes hand in hand with increase in stress.i think this is reason that springs eventually break.
INFI. H1 appears (from some extreme testing) to show very good toughness properties, even taking 90 degree bends without cracking or breaking. Of course, it's permanently bent afterwards.
