hack seconds?
I've come across descriptions for wristwatches that say that this watch or that watch has a "hack seconds" or "hacking seconds" feature. What does that mean? There's the military "time hack", but I don't know if that's related. Any ideas?
Here is a link to a watch faq from www.timezone.com
http://www.timezone.com/article.aspx?id=wwatchfaq&articleId=wwatchfaq631668591017665598
Here is what it says about "hack"
"1.1.2 What is a "hack" seconds feature?
This, AFAIK, is a military term referring to watches that stop the second hand, to allow for more accurate synchronization between two watches. In the most common type of hacking watch, when the crown is pulled out to the time-setting position, a lever is moved which contacts the rim of the balance, thus causing the movement to stop. John Davis has seen other methods used to stop the movement as well, including brakes on the third or fourth wheel.
A. Lange & Sohne have produced a watch that stops the balance when the crown is pulled out and automatically moves the second hand to the "0" position - to help facilitate setting against an accurate time reference."
