David W Babcock
Black Metal Forge
- Mar 21, 2018
Good Day!
I’ve just completed three chef knives. I’ve used 1095 and W2 for two of them, as I’ve used this steel multiple times and was also looking for a Hamon. They don’t show in the pictures as I have not etched yet. The 3rd blade and my first time using the steel is 15N20. It was 1/8th thick I had a 3 foot x 2” section.
After warping in heat treat and subsequent snapping of the blade trying to straighten, I read this forum and found you need to keep it a little thicker, so I only set the bevels and heat treated then finished grinding watching my heat closely, regular water dips. After normalizing cycles on all blades I clay wrapped.
I had read on this forum 15N20 can give a nice Hamon. I followed heat treat recipe closely, using kiln not Forge due to soak requirements, and the W2 and 1095 now that polished to 220 grit show the Hamon clearly in the right light. The 15N20 I cannot see anything? Would this be due to removal of almost full blade st cutting edge from grinding. Mostly a flat grind, so lots was removed after HT but I did not over heat the blade.
Should I bother continuing to polish for Hamon or would I save some time just putting a satin finish on it with my scotchbright belt and buffer? I’d hate to spend another couple hours sanding this one blade if there’s not going to be any activity.
Any advice? Anyone have a successful Hamon on 15N20? Did it take a huge polish to reveal it? Here’s a pic of the blades but with this camera you won’t see the activity in the other two bladesz.
