I'll find out the answer soon enough, bit I thought I'd ask anyway because it's going to be 3-4 days until I can get back out to the shop.
I forged a blade out of 5160 and today I heat treated it. Two normalizing cycles, then I went to harden it. At the last second, I decided to edge quench it instead of just plunging the blade straight down into the oil. I dropped the edge into the oil for a long 5-count, then quenched the whole thing.
After I wiped off the oil, I put it straight into a 425 degree oven for an hour. When I took it out, it was obvious that there was a nice color transition between the 1/2" or so along the edge and the rest of the body of the blade. A clearly demarcated line, if you will. (Then I did a second tempering cycle, FWIW.)
Now I know I'm not going to have a true hamon in the sense of a wavy pattern caused by the patterned application of clay and all that, but I'm wondering if I'll wind up with a visible transition after I polish the blade up to 600 or 1000 grit wet/dry.
Any thoughts?
Any thoughts?
