Thanks eveyone, yea we were smoking that day, might have been the 4th of july. I love the back yard, out little slice of heaven. I also polished the inside of the spydie hole a little. Didnt mess with the spine too much, kinda like the sharp corners. Also even with all time rubbing that down with stones, the logo is still visible. I did a lot too. first step was across the grind lines with a 320 stone untill ALL lines were gone. Then took all of the 320 lines out with a 400 stone going vertical again, then took those line out with a 600 stone horizontal again. Followed by gray scotch brite to even the lines, then a cut piece of hard buff with cleaning compound followed by green, then more brite, then the 2 compounds again. Until i got the shone and draw i was looking for. You can mess up a draw pattern very quick with one slip up. I had fun doinf it, and will be helping my buddy pimp his ti kwaiken soon.
EHilderbrant:
Once its flattened to a desired grit, i took mine up to 600, i straightend out the lines with gray scotch brite (with oil). Much finer and softer than your common maroon or more rough (3m) printed darker red scotch brite. Maroon can be used as well just not quite as soft lines. Then i took a piece cut from a hard buff (basically the buffs you get in a dremel set as long as its felt) but anyway back to the process, i took one side of the buff with a rougher cleaning compound from lowes, then followed by the green high gloss compound. Then gave another round of the gray scotch brite then the buff compounds again.
If anymore would like more info on the process, i love talking polishing. Dont want to get too carried away. alot of my stuff is out of the polishing shop and may be hard to find like the different colors of brite. Gesswin is a polishing supplier
Victorf:
those looks awesome, the crk didn't register as a one right away, the mirrors look good! If i had the bb domino or a crk i dont know if could bring myself to refinish...well maybe the domino lol
