- Aug 12, 2002
OK, I have a hunter here that I plan on hand rubbing the blade on. Picked up sand paper from 100-2000 grit(will actually start with the 220 or 320 grit sandpaper, the 100 is for shaping handles). Anyways, I want to do the lbade before attaching handles this time, as I found the problem y'all warned me of of not being able to get section of blade closest to handles done wya I wanted. So I am going to cmpletely finish the blade before attaching the handles. Now what I want to know, is how do I protect what will be a beautiful hand rubbed finish(I'm hoping so anwyas
) from getting epoxy on it, and what do I use to clean the epoxy if some does get on there? I have acetone around for various things, can I use this to clean the epoxy off if I get it while it's still wet?
I can go dig out my epoxy to see what kind it is if that will help.
If it matters, just using some omre of that same oak I used on last knife, and copper pins(figured they'd give a nice different look after brass pins in last one).
