- Apr 17, 2014
Like a lot of guys, I like the satin finish of blades. Unfortunately the amount of work can be exhausting. If I know I am doing a satin finish, I grind my blade 100% then hand sand prior to heat treating. It's much easier than hand sanding a hardened blade. I find that when I leave the grinder after 80 grit, hand sanding is still tough because of the marks that were left by the 36 grit belt that simply got polished by the 80 grit. What steps do you guys take to hand sand blades? How long do you spend on a blade? The last blade I did I used a file to remove the belt marks and that saved a lot of time but it took me an hour. 80 grit paper wasn't cutting it. Thanks
