Hand Sanding Grit Progression
I'm about to buy some more paper and want to know what grits you use for hand sanding. I see some makers with a bulk pack of every grit in stock but I don't want to drop a fortune for paper that I won't use.
I don't do much hand sanding but when I do I'll grind to 400 then hand sand at 400, 600, 1000, 1500, and occasionally use 2000
Does that sound about right for everyone or is there too big of a jump in there anywhere?
I usually go to 220 or 400 on a belt then hand sand starting with 220, 400, 600, 800, then back to 600 for the final finish. All I use for hand sanding is Rhynowet Redline. I do have some high dollar 3M paper in 1200 to rub after etching.
Hey Jason. With Rhynowhet in particular I wouldn't be too concerned about the exact grit progression. I hand finish virtually everything I make (yeah you know why) and have Redline in P80, 120, 220, 320, 500, 800, 1200 and 1500. Honestly though, I think my stuff would look about the same if I only had P120, 320, 500, 800. Other grits sometimes make it go faster (but not necessarily better).
On another thread somebody made a comment about the efficiencies of picking the most aggressive tool for the purpose at hand AND having the wisdom to put it down once it is served.
I keep thinking about that lately and readily identify with the concept, but grit selection in hand finishing isn't really like that IMHO. It's mostly a surface effect where the goals should focus on continuity, uniformity and parallelism (not necessarily to mirror finish though - as in, why not just buff the crisp right out of them.)
We have all seen blades poorly finished - all the way to 2k no less. Complete with missed waves, deep scratches, j-hooks, decarb bark and other issues. In your stainless, I'll take a well-done P320 satin any day over a rushed rookie job at P2000. Doesn't seem to matter as much with carbon-steel users as they all eventually get patinated anyway. Higher grits supposedly lend better stain/corrosion resistance but customer education is way more effective at that in my opinion.
So...bottom line: I'd suggest grinding to 400, as you do, then hand sand starting at P320, then P500, and finish at P800. Maybe buy a ten pack of each and give it a shot. All for less than $20 delivered. You already know this but patient practice with your particular gear is the real key here - regardless what materials are being used.
BTW I had a smile reading through your other "tester" thread, especially seeing your O-1 necker hammered into that Chinese-made POS. Your knives are ready to work - no doubt about it!! Sure hope to see you at DG's next month.
Andy,
Thanks for chiming in. You make some great points on quality of the lines rather than the grit of the paper. I do like carbon steel and don't do much hand sanding on it. As far as I'm concerned, the customer pays for hand sanding and $60 doesn't cover it. But I do it on higher end knives (hamon, mirror polish, etc). I have 4 blades on the table now that was requested to be presentation grade mirror polish. And two have a gut hook so that leaves out the buffer. I've been working on my 600 grit cork belt but chasing those scratches is driving me crazy. Maybe I didn't knock enough grit off before I loaded it with compound. I'll try that again this weekend.
I plan to go to Dan's. Have you heard a date yet?
