I'm curious as to the thoughts/experience of the group here regarding handle finishes. I've done some research on this topic and have noted several opinions and ideas that folks have about this. So far, I have used dymondwood which merely needs a good buff. The resin within the wood serves to give handles a nice sheen (if that is what one desires). I have also used super glue (3-5 layers)on two or three handles which also gives a nice finish on natural hard woods. Other applicants that I have not tried include Danish oil, tung oil, linseed, polyeurethane and carnauba wax (and there are still others I'm sure...got an uncle who does wood sculpture and uses linseed oil, I believe, and he melts carnauba wax into a warm pan of the linseed oil. Rubs the mixture into the wood and it's drop-dead gorgeous). I have stayed away from oil based finishes because I understand that natural hard woods will oxidize or natural oxidation is accelerated due to the oil and, as a result, the wood will darken with age. I further understand that some woods do not need a finish because of the natural oil contained in the wood itself. I think Lignum Vitae is one of these woods and only a fine grit finish (600 grit) is sufficient.
Are there other finishes that others have used with acceptable/outstanding results with natural hard woods and other materials such as micarta? Do most folks use oil-based finishes or some other finish? What other woods are there that are quite oily thus not requiring a finish of these sorts?
Thanks in advance for any/all info.
>> DeWayne <<
>> DeWayne <<
