ron finkbeiner jr
- Jan 6, 2012
Hi, I have a kukri I bought from HI and the handle has shrunk and even cracked. Any advice on how to proceed? Thanks
My horn cracked, I'm going to put some gorilla glue in there and call it a day. I'll keep an eye on it but otherwise it should last a but, based on prior experiences doing this.
If the get loose, then it's bad news.
I find this earlier this week while I was messing around in the backyard with it. I'll be liberal with application and hand sand smooth if I need to. I've filled in quite a few handle gaps in inexpensive machetes and such and it's worked well.
Yeah, I've had good luck doing that, then a buffing wheel with green or white rouge. Though, if it's a user, I probably wouldn't bother with the last part.Id use gorilla glue "super glue" fill the crack, sand down
Conditioning the horn MIGHT have prevented it, but there a number of things that could have been the root cause:I don't have any horn handled models but for general knowledge, does conditioning the horn prevent this? Not that natural materials will never split or crack but I don't know if horn can be treated like oiling a wood handle?
Did you use regular Gorilla glue or the super glue like mentioned after your post? I've got a Tramontina machete handle that's loose.My horn cracked, I'm going to put some gorilla glue in there and call it a day. I'll keep an eye on it but otherwise it should last a but, based on prior experiences doing this.
I used gorilla glue clear. In general, I'm not a fan of CA only glues for working handles just because of its lack of water resistance.Did you use regular Gorilla glue or the super glue like mentioned after your post? I've got a Tramontina machete handle that's loose.
Much appreciated, that's a helpful bit of information! Thank you.I used gorilla glue clear. In general, I'm not a fan of CA onlye glues for working handles just because of its lack of water resistance.
I've used clear on many things and it holds up well and also has a slightly tacky feel, likely from the polyurethane base. I have another large knife, a Sheffield MOD, that I used to fill a ridiculous gap in the scales and it worked well. I've used silicone to smooth out gaps on a Marbles bolo machete, before I did the Sheffield, and I wasn't as happy as the silicone clearly wears down quicker with use, but it's a lot more comfy than a 1/8" gap between the scales because they were sanded flush to the handle, and I wanted to try the silicone filler instead of sanding it flush. Quick and dirty solution that worked well enough, but not great, but was super easy.
Also, John with JK knives used gorilla glue clear and so I had a lot of experience with someone using it before I ever took on modding and making my own stuff. Being clear also looks nice, as compared to standard gorilla glue.
