Yes on the threaded hidden pins. I just off the head of a brass screw and use it for a hidden pin, or use any handy threaded material. I hate pins that show, usually. Yep on the hollowed out anchor cavities for the epoxy in the handle scales, too. As you all know, you gotta degrease all the material to be glued, as Dave says. Threaded pins will work even though you might not get the pins perfectly steril of oil, and will certainly hold much better than smooth ones. I have used smooth pin material and usually just nicked them up with a pair of sidecutters, or dikes, as some of us refer to them. I don't just use cheepo 2 part epoxy, as y'all already know. Brownells Acra Glas Gel, all the way! Wear throw away rubber gloves, or the nitral type disposable sanitary gloves when using tha 'glas. That stuff is in a sticky class all it's own, really messy. By the time I have a handle glued up, I have the entire handle smeared with the stuff, usually. One good thing about the 'glas, you have an hour working time, and it cleans up pretty easy with alcohol or most thinners. I heard that vinegar is a good cleanup medium, too. One question on the quarter inch pins. Why do you want to use that large of a pin, unless you are using exposed pins?
