Take the tape back off. If you want grip added to your stock scales, though it is completely unnecessary, stipple them, sand them, or just put one layer of tape on them. You're asking for blisters with that tape.
Post a pic of it if you can
what is good for one is not always good for another, they slip for him, so why wouldn't he want to add more texture?though it is completely unnecessary
You can also try stretching out the straps on the factory sheath. Search this forum; I believe people have had some luck by moistening the straps, forcing them closed, and letting them dry while snapped around the knife.
I put grip tape on the stock grivory scales today, not thinking about the sheath button snap. I was wondering how if you guys can recommend another way to add retention to the sheath now that I can't use the snaps.
Take the scales off and remove some material from the inside of them (the side that goes against the tang). If you don't have a grinder with a flat platen, this can be accomplished by laying coarse sandpaper on a FLAT surface like a piece of glass, and scrubbing the scales on that.
It will take a bit of trial and error, but with patience you should be able to thin them out enough that the keeper strap will fit around the wrapped scales.
