pmwc78
- Sep 4, 2010
Bought this guy a month or so back, the blem was a handle crack that was not in the best shape.
[/URL][/IMG]
the crack ran along the spine and was 3" starting under the bolster an running down the handle.
So......
Off, with his horn!
[/URL][/IMG]
ground off the peen, and pried the horn apart starting at the split. Chipped the laha out from under the bolster too.
That handle was way too long for my hands.
Next, time to trim up.
[/URL][/IMG]
cut off an inch of the tang, and notched it to fit the buttcap again. I peened the cap back on, trimmed a 1/4" off the bottom of the bolster the re-attached by packing with epoxy putty.
Time to rebuild.
I used the handle wrap method to make Micarta-ish handles. There are videos online for a how-to.
follow all the safety recommendations you see, there is no such thing as too much ventilation.
grind, grind, grind
[/URL][/IMG]
[/URL][/IMG]
Still some cleanup to do and this is far from a best effort. I spent plenty of time learning how not to do this along the way.
Fun project overall, if you are looking a buying a blem it may be worth the effort to make it a very good knife that is undeniably "yours"
So......
Off, with his horn!
Time to rebuild.
grind, grind, grind
